Mitsubishi VLT-HC3800LP Bulb Replacement
  1. Mitsubishi VLT-HC3800LP Bulb Replacement, Bulb: step 1, image 1 of 1
    • Remove both screws as shown and gently pull the metallic frame. It is anchored on two small notches on the other side.
  2. Mitsubishi VLT-HC3800LP Bulb Replacement: step 2, image 1 of 3 Mitsubishi VLT-HC3800LP Bulb Replacement: step 2, image 2 of 3 Mitsubishi VLT-HC3800LP Bulb Replacement: step 2, image 3 of 3
    • Remove both screws onn the handle side, and both dark screws on the opposite side.
    • Slightly pull the metal frame (1) and lift the housing top half (2) to reveal the bulb.
  3. Mitsubishi VLT-HC3800LP Bulb Replacement: step 3, image 1 of 3 Mitsubishi VLT-HC3800LP Bulb Replacement: step 3, image 2 of 3 Mitsubishi VLT-HC3800LP Bulb Replacement: step 3, image 3 of 3
    • Remove the black stickers hiding both screws that will have to be removed in this step.
  4. Mitsubishi VLT-HC3800LP Bulb Replacement: step 4, image 1 of 1
    • Lift the bulb and its holder from the housing frame.
    • It will then be easier to disconnect the cables
  5. Mitsubishi VLT-HC3800LP Bulb Replacement: step 5, image 1 of 3 Mitsubishi VLT-HC3800LP Bulb Replacement: step 5, image 2 of 3 Mitsubishi VLT-HC3800LP Bulb Replacement: step 5, image 3 of 3
    • Remove the 4 screws and gently lift the frame maintaining the bulb.
    • Note the two notches which will only allow one way to mount the frame.
    • Note the bulb's contacts orientation.
    • Handle the replacement bulb with extreme care. Avoid touching it with bare hands. Bulbs don't like fingerprints at all!
  6. Mitsubishi VLT-HC3800LP Bulb Replacement: step 6, image 1 of 1
    • Done!
    • Put the lamp back in place according to your projector's user manual.
2 other people completed this guide.
ralf
333 Reputation
2 Guides authored
One Comment
Did my Mitsubishi HC4000 today with lamp only..Found this after the event but useful anyway!
swingmanic - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 8,686
