Samsung L100 camera lens replacement
  1. Samsung L100 camera lens replacement, Removing Back Cover: step 1, image 1 of 3 Samsung L100 camera lens replacement, Removing Back Cover: step 1, image 2 of 3 Samsung L100 camera lens replacement, Removing Back Cover: step 1, image 3 of 3
    • Remove the six external screws from the camera using a Phillips #0 screwdriver.
    • After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
    • Be careful, make sure you don't lose the screws.
  2. Samsung L100 camera lens replacement: step 2, image 1 of 2 Samsung L100 camera lens replacement: step 2, image 2 of 2
    • Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
  3. Samsung L100 camera lens replacement: step 3, image 1 of 3 Samsung L100 camera lens replacement: step 3, image 2 of 3 Samsung L100 camera lens replacement: step 3, image 3 of 3
    • Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
  4. Samsung L100 camera lens replacement: step 4, image 1 of 1
    • Carefully squeeze the top right corner of the camera and pry off the external cover.
    • If you hear a "cracking" sound. This is normal.
    • Continue to pull the external cover and it will come off cleanly.
    • Be cautious of the flash capacitor. It carries an electrical charge, that may give you an unpleasant shock.
  5. Samsung L100 camera lens replacement: step 5, image 1 of 1
    • Carefully pull off the back cover, parts behind the back of the case might fall out.
  6. Samsung L100 camera lens replacement, Camera Lens: step 6, image 1 of 1
    • Remove the front cover, it comes off easily.
    • Buttons might fall out when you remove the front cover.
  7. Samsung L100 camera lens replacement: step 7, image 1 of 1
    • Remove green tape from ribbon.
  8. Samsung L100 camera lens replacement: step 8, image 1 of 2 Samsung L100 camera lens replacement: step 8, image 2 of 2
    • Remove four screws around lens.
  9. Samsung L100 camera lens replacement: step 9, image 1 of 1
    • Use spudger to remove ribbon connecting the circuit board from lens.
  10. Samsung L100 camera lens replacement: step 10, image 1 of 1
    • Remove lens from camera.
5 other people completed this guide.
Adriel
126 Reputation
2 Guides authored
Cal Poly, Team 6-17, Maness Spring 2010 Member of Cal Poly, Team 6-17, Maness Spring 2010
CPSU-MANESS-S10S6G17
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 48
All Time: 10,575
