Introduction
This guide provide procedure to replace the hard disk or SSD.
Ensure the electrical power is totally off prior to perform the replacement procedure.
Locate Hard Disk/SSD compartment door and locking latch.
Slide the locking latch to the right side.
With the locking latch is fully slid to the right side, slide it downward to unlock.
Pull the compartment door and it will be opened.
With the compartment door fully opened, check the inside of the compartment.
Locate the caddy and small plastic handle on it.
Hold the small plastic handle and pull it out to remove the caddy assembly from the laptop. Applying small amount force would be required.
Visually check the exterior condition of the caddy.
Locate the locking latch on the right and left side of the caddy compartment. Two (2) latches are on each side, totally four (4) latches are on the caddy.
Unlock the latches by smoothly push the plastic part of the caddy.
Flip the caddy once you unlocked the all four (4) latches.
Pull the metal cover of the caddy upwards to open it.
Move the transparent plastic film at the top layer.
Move the Flat Printed Circuit (FPC) upwards. You may see the hard disk/SSD under the transparent film.
Raise the last layer of the transparent film to the hard disk is totally exposed.
Pull out the SATA connector routed to the hard disk/SSD. Pulling out the connector upwards to remove it.
Pull out the transparent film at the top layer upwards. Put singers into the small gap between caddy and cushon/films.
Disconnect the connector from the hard disk/SSD.
Get the replacement HDD/SDD ready. Ensure there is no foreign objects on the electrical connectors.
Put the replacement HDD/SSD into the caddy components.
Connect the SATA connector. Connector shall be located inside of the black sponge cushion.
Restore the layers of the protective film and heater mat. Transparent film - Heater Mat - Transparent film.
Put the caddy components with the HDD/SSD into the caddy.
Once the components are sit into the caddy, install the connector. There is a guide structure for connector, inside of the caddy rim.
Close the metal cover for the caddy.
Reinstall the completed caddy onto the CF-19 laptop.
To reassemble the device, follow the instructions in reverse order.
Special thanks to these translators:
100%
김또임 is helping us fix the world! Want to contribute?
Start translating ›
