Introduction
This guide will show you how to replace the motor protection filter and exhaust filter on the Philips PowerPro Active 2000W vacuum cleaner, model number FC8670. This can be done by hand and requires the Philips PowerPro Active/PowerPro Compact Replacement kit FC8058/01.
It is recommended that these filters are replaced annually. During these 12 months, monthly cleaning is recommended to ensure the filters are working optimally.
Press the Eject button on top of the vacuum cleaner to remove the dust drum.
Pull the drum upwards using the handle. This will give you access to the motor protection filter.
Return the dry sponge to the backside of the motor protection filter.
If you are replacing the filter entirely, remove it from the box and place it on the back of the dust drum.
Ensure that the blue tab is aligned with the bar that protrudes from the back of the dust drum to fit the filter correctly.
Pick away any large pieces of debris from the filter using your hands. You can then return it to the exhaust filter grill.
If replacing with a new filter, remove the new filter from the box and place it over the exhaust filter.
Return the grill to the back of the vacuum cleaner, while making sure that the filter is aligned correctly. Press the grill up until it clicks and is held in place.
