Replace faultly digit
    1. Replace faultly digit, Display digit: step 1, image 1 of 3 Replace faultly digit, Display digit: step 1, image 2 of 3 Replace faultly digit, Display digit: step 1, image 3 of 3
      • Unplug the power supply from the wall, remove batteries.
      • Unscrew x7 and open the device by unlocking the plastic clip on the bottom face.
      • On the rear of the display panel, unscrew x2 and unclip the flat cable.
      Ask FixBot
    2. Replace faultly digit: step 2, image 1 of 3 Replace faultly digit: step 2, image 2 of 3 Replace faultly digit: step 2, image 3 of 3
      • We want to separate the digit support from the PCB to access the leds.
      • On the back, mill the white clips to free the PCB from the digit support. I used a Dremel like tool.
      Ask FixBot
    3. Replace faultly digit: step 3, image 1 of 2 Replace faultly digit: step 3, image 2 of 2
      • You can test the leds by plug in the flat cable. Be carefull of high voltage.
      • In my case, I had to replace the 2B led. Locate the green mark before unsoldering the led. Green mark goes to the driver chip.
      • To buy leds, search Internet with key words : white led smd 0603
      Ask FixBot
      • Once done, you can try the led fix and reassemble the device.
      Ask FixBot
Pour réassembler votre appareil, suivez les instructions dans l'ordre inverse.
Pierre Le Gargasson
579 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 19
Past 30 Days: 49
All Time: 315
