Replace Whirlpool pressure switch
    1. Replace Whirlpool pressure switch, Gecko pressure switch: step 1, image 1 of 2 Replace Whirlpool pressure switch, Gecko pressure switch: step 1, image 2 of 2
      • Locate the pressure valve
      Ask FixBot
    2. Replace Whirlpool pressure switch: step 2, image 1 of 2 Replace Whirlpool pressure switch: step 2, image 2 of 2
      • Use a Phillips screwdriver to loosen the screw
      • open the lid
      Ask FixBot
    3. Replace Whirlpool pressure switch: step 3, image 1 of 3 Replace Whirlpool pressure switch: step 3, image 2 of 3 Replace Whirlpool pressure switch: step 3, image 3 of 3
      • Disconnect the plug from the pressure switch
      Ask FixBot
    4. Replace Whirlpool pressure switch: step 4, image 1 of 3 Replace Whirlpool pressure switch: step 4, image 2 of 3 Replace Whirlpool pressure switch: step 4, image 3 of 3
      • Route the pressure switch cable out of the control box
      Ask FixBot
    5. Replace Whirlpool pressure switch: step 5, image 1 of 3 Replace Whirlpool pressure switch: step 5, image 2 of 3 Replace Whirlpool pressure switch: step 5, image 3 of 3
      • Cut off the cable ties
      • Peel off the rubber
      • Pull off the electrical contacts
      • It doesn't matter which way around the contacts are reconnected during assembly
      Ask FixBot
    6. Replace Whirlpool pressure switch: step 6, image 1 of 2 Replace Whirlpool pressure switch: step 6, image 2 of 2
      • Unscrew the pressure switch with an open-end wrench
      • Check whether there is any dirt in the openings of the pressure switch and the holder. If necessary, remove the dirt.
      Ask FixBot
Follow these steps in reverse order to reassemble your device
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
AquaWhirlpools
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 121
All Time: 2,822
