Replace Kärcher RC3000 brush motor. replacement
  1. Replace Kärcher RC3000 brush motor. replacement, Replace brush motor.: step 1, image 1 of 1
    • Remove both batteries.
    • Tools: Wide slotted screwdriver or better 20 Torx.
  2. Replace Kärcher RC3000 brush motor. replacement: step 2, image 1 of 1
    • Remove protective rubber collision protection and cover.
  3. Replace Kärcher RC3000 brush motor. replacement: step 3, image 1 of 2 Replace Kärcher RC3000 brush motor. replacement: step 3, image 2 of 2
    • Unplug the on/off switch.
    • Unplug the connector for the charging contacts.
  4. Replace Kärcher RC3000 brush motor. replacement: step 4, image 1 of 3 Replace Kärcher RC3000 brush motor. replacement: step 4, image 2 of 3 Replace Kärcher RC3000 brush motor. replacement: step 4, image 3 of 3
    • remove pins. Caution, risk of injury for the inexperienced.
  5. Replace Kärcher RC3000 brush motor. replacement: step 5, image 1 of 1
    • Detach outer upper case (do not remove yet!). To do this, loosen 4 screws. With slotted screwdriver or 8 Torx.
  6. Replace Kärcher RC3000 brush motor. replacement: step 6, image 1 of 1
    • rotate device. Hold both frames. Be careful, the screws will fall out. 4 left?
    • Now carefully remove the upper cover without pressing the lower part down. Then the springs remain mounted!
  7. Replace Kärcher RC3000 brush motor. replacement: step 7, image 1 of 2 Replace Kärcher RC3000 brush motor. replacement: step 7, image 2 of 2
    • Disconnect the brush motor connector.
    • ..and the others on the site too.
  8. Replace Kärcher RC3000 brush motor. replacement: step 8, image 1 of 2 Replace Kärcher RC3000 brush motor. replacement: step 8, image 2 of 2
    • Remove brush motor.
    • Congratulations, mountain party
  9. Replace Kärcher RC3000 brush motor. replacement: step 9, image 1 of 1
    • Install new brush motor.
  10. Replace Kärcher RC3000 brush motor. replacement: step 10, image 1 of 3 Replace Kärcher RC3000 brush motor. replacement: step 10, image 2 of 3 Replace Kärcher RC3000 brush motor. replacement: step 10, image 3 of 3
    • plug in.
  11. Replace Kärcher RC3000 brush motor. replacement: step 11, image 1 of 3 Replace Kärcher RC3000 brush motor. replacement: step 11, image 2 of 3 Replace Kärcher RC3000 brush motor. replacement: step 11, image 3 of 3
    • ...put on more plugs.
  12. Replace Kärcher RC3000 brush motor. replacement: step 12, image 1 of 3 Replace Kärcher RC3000 brush motor. replacement: step 12, image 2 of 3 Replace Kärcher RC3000 brush motor. replacement: step 12, image 3 of 3
    • Check the sensors for correct seating
    • Put the top lid on. Make sure that the cover is assembled without using force!
    • rotate device. Hold the two frame parts together well.
    • Do the sensors sit well in the frame?
  13. Replace Kärcher RC3000 brush motor. replacement: step 13, image 1 of 2 Replace Kärcher RC3000 brush motor. replacement: step 13, image 2 of 2
    • The pins that must hold the spring must dip into the opposite frame part.
    • Only then can the frame be screwed on on this side.
    • The same on the other side.
    • Also install the remaining two screws. When tightening, ensure that the frames are evenly spaced apart.
  14. Replace Kärcher RC3000 brush motor. replacement: step 14, image 1 of 2 Replace Kärcher RC3000 brush motor. replacement: step 14, image 2 of 2
    • Reinsert the pins for the brush from the correct side.
  15. Replace Kärcher RC3000 brush motor. replacement: step 15, image 1 of 2 Replace Kärcher RC3000 brush motor. replacement: step 15, image 2 of 2
    • Insert pins to the end.
  16. Replace Kärcher RC3000 brush motor. replacement: step 16, image 1 of 2 Replace Kärcher RC3000 brush motor. replacement: step 16, image 2 of 2
    • Install brush
    • attach the cover
    • rotate device
  17. Replace Kärcher RC3000 brush motor. replacement: step 17, image 1 of 2 Replace Kärcher RC3000 brush motor. replacement: step 17, image 2 of 2
    • Plug in the connector for the charging contacts
    • Plug for the on/off switch..
  18. Replace Kärcher RC3000 brush motor. replacement: step 18, image 1 of 2 Replace Kärcher RC3000 brush motor. replacement: step 18, image 2 of 2
    • Mount the yellow cover
    • Mount the bumper
    • Install batteries
    • Testing
Special thanks to these translators:
de en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
Michael Kappich
101 Reputation
1 Guide authored
One Comment
Danke - hat super geklappt! Vorsicht bei den weißen, dünnen Plastikstiften die den Bürstenmotor vorne noch begrenzen - brechen gerne ab.
thenotoriousflow - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 11
All Time: 911
