Sony Cassette Deck TC KE200 Repair
  1. Sony Cassette Deck TC KE200 Repair, Motor Belt: step 1, image 1 of 3 Sony Cassette Deck TC KE200 Repair, Motor Belt: step 1, image 2 of 3 Sony Cassette Deck TC KE200 Repair, Motor Belt: step 1, image 3 of 3
    • Remove the screws from the bottom.
    • Remove the screws from the side.
    • Carefully remove the cassette deck from the metal base.
  2. Sony Cassette Deck TC KE200 Repair: step 2, image 1 of 2 Sony Cassette Deck TC KE200 Repair: step 2, image 2 of 2
    • Remove the black cable on the left side.
    • Remove the white flat ribbon cables.
    • Remove the small screw in order to change the ruble inside the cassette player mechanisms.
    • Remove the gray power cables.
  3. Sony Cassette Deck TC KE200 Repair: step 3, image 1 of 2 Sony Cassette Deck TC KE200 Repair: step 3, image 2 of 2
    • Remove the small screw.
    • Now you should be able to see the wheel location. Change the rubber.
  4. Sony Cassette Deck TC KE200 Repair: step 4, image 1 of 2 Sony Cassette Deck TC KE200 Repair: step 4, image 2 of 2
    • Replace the big belt.
    • Replace the small (green) belt.
    • Use a little tape to hold the belt. When closing, remove the tape.
  5. Sony Cassette Deck TC KE200 Repair: step 5, image 1 of 2 Sony Cassette Deck TC KE200 Repair: step 5, image 2 of 2
    • Insert the small screw and close the cassette player with new straps.
    • Connect all cables and flat, white ribbon cables.
    • Close everything up and you're done with the repair!
    • Hope this repair helped you, please leave a comment!
2 other people completed this guide.
Special thanks to these translators:
pt en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Cafony
687 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 19
All Time: 1,533
