Repairing a Panasonic SA-HT810V with the H02/H07 error
  1. Repairing a Panasonic SA-HT810V with the H02/H07 error, H02/H07 error: step 1, image 1 of 3 Repairing a Panasonic SA-HT810V with the H02/H07 error, H02/H07 error: step 1, image 2 of 3 Repairing a Panasonic SA-HT810V with the H02/H07 error, H02/H07 error: step 1, image 3 of 3
    • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
    • Remove the screw that is on the right side of the panel facing you.
    • Now rotate the device 180 degrees and remove the second screw.
    • Remove all screws with a phillips head screwdriver.
  2. Repairing a Panasonic SA-HT810V with the H02/H07 error: step 2, image 1 of 2 Repairing a Panasonic SA-HT810V with the H02/H07 error: step 2, image 2 of 2
    • Rotate the device so that the back faces you.
    • With a phillips head screwdriver, locate and remove the two screws highlighted by the red circles in image one.
  3. Repairing a Panasonic SA-HT810V with the H02/H07 error: step 3, image 1 of 1
    • Before removing top cover make sure that the back of the device is facing you.
    • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
  4. Repairing a Panasonic SA-HT810V with the H02/H07 error: step 4, image 1 of 2 Repairing a Panasonic SA-HT810V with the H02/H07 error: step 4, image 2 of 2
    • Note that the spindle you will be lubing is located underneath the white disk device highlighted in figure one
    • Tilt the device on its front side until you can see underneath the white circular component mentioned in the note above.
    • Locate the spindle circled in figure two and apply one or two drops of 3 in 1 lubricating oil to the spindle.
Nathan Cheadle
161 Reputation
7 Guides authored
Cal Poly, Team 16-5, Maness Spring 2010 Member of Cal Poly, Team 16-5, Maness Spring 2010
CPSU-MANESS-S10S16G5
4 Members
7 Guides authored
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 38
All Time: 27,960
