Remington S5500 Power Supply Cable Removal
Views: 9.4K
View statistics:
Past 24 Hours:
11
Past 7 Days:
58
Past 30 Days:
215
All Time:
9,355
Comments: 7
1 comment on steps, 6 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
Two tools required for the completion of this task include a PH1 screwdriver, and a prying tool.
All screws on this device are 10mm (0.393 in).
Tools
    1. Remington S5500 Power Supply Cable Removal, Power Supply Cable: step 1, image 1 of 2 Remington S5500 Power Supply Cable Removal, Power Supply Cable: step 1, image 2 of 2
      • Place the prying tool in between the hair straightener and the aligning cap.
      • Push forwards on the prying tool to pop off the aligning cap.
      Ask FixBot
    2. Remington S5500 Power Supply Cable Removal: step 2, image 1 of 3 Remington S5500 Power Supply Cable Removal: step 2, image 2 of 3 Remington S5500 Power Supply Cable Removal: step 2, image 3 of 3
      • Remove the screws with the Phillips #1 screwdriver located underneath the aligning cap, one on each side of the straightener.
      • Use the prying tool to remove the aligning rods after the removal of the screws.
      • Gently separate each half of the hair straightener.
      • The spring located in the middle of this mechanism may pop out and can get lost very easily. Try to separate the two components slowly.
      Ask FixBot
    3. Remington S5500 Power Supply Cable Removal: step 3, image 1 of 2 Remington S5500 Power Supply Cable Removal: step 3, image 2 of 2
      • After the hair straightener is separated, use a Phillips #1 screwdriver to remove the two screws located on the lower half of the straightener.
      • Use the prying tool to remove the hinge cover.
      Ask FixBot
    4. Remington S5500 Power Supply Cable Removal: step 4, image 1 of 2 Remington S5500 Power Supply Cable Removal: step 4, image 2 of 2
      • Pull upwards while pulling outwards to disconnect the wire from the housing.
      Ask FixBot
5 other people completed this guide.
Benjamin Yohe
375 Reputation
2 Guides authored
IUPUI, Team S3-G3, Wilson Summer 2018 Member of IUPUI, Team S3-G3, Wilson Summer 2018
IUPUI-WILSON-SU18S3G3
5 Members
24 Guides authored
6 Guide Comments
Excelente trabajo! Muchas gracias por la información!
Ronnetto - Reply Share
is there a place where you can buy and replace the power cable, or the plug ?
alexandru popa - Reply Share
the slip ring plug that is ..
Hello,
from where did you get the spare power cord ?
Kes - Reply Share
part number would be helpful?
Steven Lamprell - Reply Share
Past 24 Hours: 11
Past 7 Days: 58
Past 30 Days: 215
All Time: 9,355
