Introduction
If your in-line amplifier has stuck or sticky volume wheels then it may need to be cleaned.
Remove the 4 screws from the inline amplifier using a #6 torque screwdriver head. The screws measure 1/4" long and 3/32" in diameter.
Open the amplifier by using the smaller plastic opening tool. Place it in the headphone jack and use leverage to pry open the plastic halves.
When done cleaning, place the circuit board back in the plastic housing.
The scroll wheels should be facing the housing with the logo and labels, and should slide onto the 4 screw holes.
Make sure the plastic headphone jack brace is in position.
Position the wire in the slot on the other side of the amplifier, it should slide down onto the housing and become fixed.
Close the housing with the other plastic half. It will click into place.
Replace the 4 screws using the #6 torque screwdriver.
