Toshiba Satellite A105-S4284 LCD Display Replacement
  1. Toshiba Satellite A105-S4284 LCD Display Replacement, Keyboard: step 1, image 1 of 1
    • Flip the laptop over so it is rightside up, and open the laptop all the way so that the screen is horizontal.
  2. Toshiba Satellite A105-S4284 LCD Display Replacement: step 2, image 1 of 3 Toshiba Satellite A105-S4284 LCD Display Replacement: step 2, image 2 of 3 Toshiba Satellite A105-S4284 LCD Display Replacement: step 2, image 3 of 3
    • Using the plastic opening tool, pry off the panel above the keyboard, starting near the right front speaker.
    • Use the plastic opening tool to pop off tabs along the length of this panel.
    • This may feel like you're about to break something, but as long as you work your way down the panel and don't yank it out, the laptop will be fine.
  3. Toshiba Satellite A105-S4284 LCD Display Replacement: step 3, image 1 of 2 Toshiba Satellite A105-S4284 LCD Display Replacement: step 3, image 2 of 2
    • Unscrew the two 4.5 mm screws holding the keyboard on with the Phillips #1 screwdriver.
  4. Toshiba Satellite A105-S4284 LCD Display Replacement: step 4, image 1 of 3 Toshiba Satellite A105-S4284 LCD Display Replacement: step 4, image 2 of 3 Toshiba Satellite A105-S4284 LCD Display Replacement: step 4, image 3 of 3
    • Lift the keyboard gently from the side closest the screen.
    • Pull out the ribbon connecting the keyboard to the laptop.
  5. Toshiba Satellite A105-S4284 LCD Display Replacement, Battery: step 5, image 1 of 2 Toshiba Satellite A105-S4284 LCD Display Replacement, Battery: step 5, image 2 of 2
    • Make sure your computer is turned off and the computer is not plugged in.
    • Turn your laptop upside down, and slide the right release tab outward.
    • Using you left hand, hold the left release tab towards the left side and then pull the battery out.
  6. Toshiba Satellite A105-S4284 LCD Display Replacement, LCD Display: step 6, image 1 of 3 Toshiba Satellite A105-S4284 LCD Display Replacement, LCD Display: step 6, image 2 of 3 Toshiba Satellite A105-S4284 LCD Display Replacement, LCD Display: step 6, image 3 of 3
    • Remove the black and white wires. they simply lift off the posts.
    • Remove the cable attaching the LCD to the motherboard, on the left side of the laptop.
  7. Toshiba Satellite A105-S4284 LCD Display Replacement: step 7, image 1 of 2 Toshiba Satellite A105-S4284 LCD Display Replacement: step 7, image 2 of 2
    • Using the Phillips screwdriver remove the two 4.0mm screws from each hinge above speakers.
    • Partially close the lid and remove the last two 4.0mm screws from the back of the laptop.
  8. Toshiba Satellite A105-S4284 LCD Display Replacement: step 8, image 1 of 3 Toshiba Satellite A105-S4284 LCD Display Replacement: step 8, image 2 of 3 Toshiba Satellite A105-S4284 LCD Display Replacement: step 8, image 3 of 3
    • Peel off the rubber circles from the four corners.
    • Remove the four 4.0mm phillips screws.
  9. Toshiba Satellite A105-S4284 LCD Display Replacement: step 9, image 1 of 3 Toshiba Satellite A105-S4284 LCD Display Replacement: step 9, image 2 of 3 Toshiba Satellite A105-S4284 LCD Display Replacement: step 9, image 3 of 3
    • Using the plastic prying tools separate the plastic surrounding the screen
    • Lift out the broken LCD to be replaced.
Josh
685 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 1,890
