Samsung SGH-A237 Keypad Replacement
  1. Samsung SGH-A237 Keypad Replacement, Keypad: step 1, image 1 of 2 Samsung SGH-A237 Keypad Replacement, Keypad: step 1, image 2 of 2
    • Place phone face down so battery cover is showing.
  2. Samsung SGH-A237 Keypad Replacement: step 2, image 1 of 2 Samsung SGH-A237 Keypad Replacement: step 2, image 2 of 2
    • Use thumb to push the cover down and off.
    • Lift battery cover off the device.
  3. Samsung SGH-A237 Keypad Replacement: step 3, image 1 of 2 Samsung SGH-A237 Keypad Replacement: step 3, image 2 of 2
    • Remove the five screws with a size 00 screwdriver. There are 4 in the corners and one on the top as shown.
  4. Samsung SGH-A237 Keypad Replacement: step 4, image 1 of 3 Samsung SGH-A237 Keypad Replacement: step 4, image 2 of 3 Samsung SGH-A237 Keypad Replacement: step 4, image 3 of 3
    • Be sure that all 5 screws are removed and start to carefully remove the back cover by using the iPod Opening Tool in the slots on the bottom of the device.
    • Some force must be applied, and the back cover should come off.
  5. Samsung SGH-A237 Keypad Replacement: step 5, image 1 of 1
    • Detach the tab from the logic board shown by using the Ipod Opening Tool
  6. Samsung SGH-A237 Keypad Replacement: step 6, image 1 of 2 Samsung SGH-A237 Keypad Replacement: step 6, image 2 of 2
    • Use the Ipod Opening Tool to lift the green logic board carefully.
    • Remove the logic board from the device.
  7. Samsung SGH-A237 Keypad Replacement: step 7, image 1 of 1
    • The keypad should peel off the logic board with a gentle pull.
    • Use a clean, soft, cotton cloth to gently remove any debris or liquid that may be located on the pad or logic board interface.
Shawn
1 Reputation
2 Guides authored
Cal Poly, Team 29-81, Johann Spring 2010 Member of Cal Poly, Team 29-81, Johann Spring 2010
CPSU-JOHANN-S10S29G81
4 Members
8 Guides authored
One Comment
This was very helpful. There is no other place I could find a guide to take this phone apart. Even Samsung chat was unable to help!! Thanks very much!
Steve - Reply
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 13
All Time: 2,315
