Nokia 2115i Faceplate Replacement
  1. Nokia 2115i Faceplate Replacement, Nokia 2115i Battery: step 1, image 1 of 3 Nokia 2115i Faceplate Replacement, Nokia 2115i Battery: step 1, image 2 of 3 Nokia 2115i Faceplate Replacement, Nokia 2115i Battery: step 1, image 3 of 3
    • To prevent shock, press down on the power button located on the top of the phone until the phone shuts off.
    • Press down on the small gray button located on the back of the phone.
    • Slide the back plate down and off.
  2. Nokia 2115i Faceplate Replacement: step 2, image 1 of 2 Nokia 2115i Faceplate Replacement: step 2, image 2 of 2
    • To remove the battery, begin by holding the phone sideways.
    • Then, insert your thumb in the groove below the battery and push the battery up and out.
  3. Nokia 2115i Faceplate Replacement, Faceplate: step 3, image 1 of 3 Nokia 2115i Faceplate Replacement, Faceplate: step 3, image 2 of 3 Nokia 2115i Faceplate Replacement, Faceplate: step 3, image 3 of 3
    • Locate the spudger. A photo of the correct spudger is provided to the left.
    • Turn the front of the phone to face you. Find the two small square holes on the bottom left and right sides of the faceplate.
    • Insert the spudger into each square hole and push up to detach the face plate.
Shane
80 Reputation
6 Guides authored
Cal Poly, Team 14-38, Forte Fall 2010 Member of Cal Poly, Team 14-38, Forte Fall 2010
CPSU-FORTE-F10S14G38
5 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 1,567
