Repairing Noisy fan on MSI Wind
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Repairing Noisy fan on MSI Wind, Disassembly: step 1, image 1 of 1
    • Remove battery
    • Turn Netbook upside down
    • Unscrew all screws from the back of the pc
    • Remove the back plate
    • Unscrew metal cover on top of fan
  2. Repairing Noisy fan on MSI Wind, Removing the fan: step 2, image 1 of 3 Repairing Noisy fan on MSI Wind, Removing the fan: step 2, image 2 of 3 Repairing Noisy fan on MSI Wind, Removing the fan: step 2, image 3 of 3
    • Gently lift the fan making sure not to drop dust into the motor of the fan below
    • Clean fan blades
    • Clean the fan house
    • place the fan upside down so the metal pin points upwards
  3. Repairing Noisy fan on MSI Wind: step 3, image 1 of 1
    • Apply oil
    • Apply one or two droplets of oil onto the metal pin
    • Place it on the motor and make sure it rotates without problems
    • In case there is still sounds coming from the fan when turned on, redo the cleaning and lubrication.
    • Assemble everything and test
Knud
377 Reputation
1 Guide authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 4,169
