Motorola V710 Vibrating Motor Replacement
  1. Motorola V710 Vibrating Motor Replacement, Screen: step 1, image 1 of 3 Motorola V710 Vibrating Motor Replacement, Screen: step 1, image 2 of 3 Motorola V710 Vibrating Motor Replacement, Screen: step 1, image 3 of 3
    • Insert the spudger between the gray and black plates of the screen casing.
    • Using a twist and pry motion work your way around the phone slowly prying the two plates apart.
    • Note: this part of the phone is glued and will require re-gluing to return the phone to its original state.
  2. Motorola V710 Vibrating Motor Replacement: step 2, image 1 of 2 Motorola V710 Vibrating Motor Replacement: step 2, image 2 of 2
    • If you look at the side of the now exposed screen there should be a metal casing held onto the phone by two tabs.
    • Insert the spudger underneath one of the corners of the metal and bend it out enough to slip it over the tabs.
    • This metal is reasonably resistant to bending and will likely require a good deal of force to get it off the phone.
  3. Motorola V710 Vibrating Motor Replacement: step 3, image 1 of 2 Motorola V710 Vibrating Motor Replacement: step 3, image 2 of 2
    • Orient the phone so that the main screen is facing upward.
    • Locate the hinge casing, a dark gray piece that covers the hinge.
    • Insert the spudger under one of the top corners of this piece and using a twist and pry motion remove from the phone.
  4. Motorola V710 Vibrating Motor Replacement: step 4, image 1 of 2 Motorola V710 Vibrating Motor Replacement: step 4, image 2 of 2
    • Use the spudger to pry upward and remove the plug that connects the screen to the main body of the phone.
  5. Motorola V710 Vibrating Motor Replacement: step 5, image 1 of 2 Motorola V710 Vibrating Motor Replacement: step 5, image 2 of 2
    • Insert the spudger under the screen and pry the screen forward.
    • Remove the plug on the back of the screen that connects it to the camera.
  6. Motorola V710 Vibrating Motor Replacement: step 6, image 1 of 2 Motorola V710 Vibrating Motor Replacement: step 6, image 2 of 2
    • Use the spudger to remove the screen.
  7. Motorola V710 Vibrating Motor Replacement, Vibrating Motor: step 7, image 1 of 2 Motorola V710 Vibrating Motor Replacement, Vibrating Motor: step 7, image 2 of 2
    • Remove the vibrating motor from the phone with the spudger.
Karl Sanders
8 Reputation
7 Guides authored
Cal Poly, Team 8-49, Regan Winter 2010 Member of Cal Poly, Team 8-49, Regan Winter 2010
CPSU-REGAN-W10S8G49
5 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 14
All Time: 4,676
