identify the exact type of your ThinkPad
get the right fan assembly, in this case FRU P/N: 42W2779
disconnect power-supply
detach battery
unscrew all the shown screws
These ones are tiny
carefully pull out the keyboard bezel
flip the bezel 180°
This is a really great procedure. My comment is very close to the one above.
At step 10, between the first and second bullet:
Close the screen and flip the computer over.
Remove the two screws at the backside upper edges. this will free up the keyboard bezel. (Look at the screws pictured in step 3 circled in red.)
On the left, the screw to remove is a the 5 o'clock position to the red circle.
On the right, the screw to remove is at the 2 o'clock position to the red circle.
Flip the computer back over and open it up with the screen at a 90 degree angle to the keyboard (now removed)
In this position it will be much easier to remove the keyboard bezel.
Thanks again, my wife was very happy to get her computer back in working order.
James
get some alcohol on the wiper
clean the CPU with the wiper
clean the chip with the wiper
Ensure there is no old thermal grease left
Follow this guide to add new thermal paste to the CPU.
now place the new fan assembly
press down the CPU- and chip-connector
don't forget to plugin the power cable of the fan assembly
Can you please tell me where I can get a Lenovo Thinkpad Rseries R61 Type 8918-DEG fan because I nedd to replace my old one. (I live in South Africa)
6 other people completed this guide.
2 Comments
This worked perfectly for a couple of my IBM Lenovo R61s. It was spot on except in step 3 you need to remove both screws by the red circles in order to the get inside bezel off, for the R61 anyway. Thanks for the great tutorial!
Excellent guide! It took me less than 1 hour to complete all the steps, and get my R61 up and running again! Thanks a lot
