LG 1010 Keypad Replacement
  1. LG 1010 Keypad Replacement, Battery: step 1, image 1 of 1
    • Turn off the cell phone and place face down on a flat surface.
  2. LG 1010 Keypad Replacement: step 2, image 1 of 2 LG 1010 Keypad Replacement: step 2, image 2 of 2
    • While sliding the gray tab up, lift battery up and away from the cell phone.
  3. LG 1010 Keypad Replacement: step 3, image 1 of 3 LG 1010 Keypad Replacement: step 3, image 2 of 3 LG 1010 Keypad Replacement: step 3, image 3 of 3
    • Remove battery and set aside.
  4. LG 1010 Keypad Replacement, Antenna: step 4, image 1 of 1
    • While holding cell phone firmly in one hand, unscrew and remove the antenna with the other hand.
  5. LG 1010 Keypad Replacement: step 5, image 1 of 2 LG 1010 Keypad Replacement: step 5, image 2 of 2
    • Pull the antenna housing (black tube) towards bottom of phone and remove.
  6. LG 1010 Keypad Replacement, Back Cover: step 6, image 1 of 2 LG 1010 Keypad Replacement, Back Cover: step 6, image 2 of 2
    • Unscrew the four screws on the back case using a T6 Torx Screwdriver.
  7. LG 1010 Keypad Replacement: step 7, image 1 of 2 LG 1010 Keypad Replacement: step 7, image 2 of 2
    • Pull the back cover straight off the phone using your thumb and forefinger.
  8. LG 1010 Keypad Replacement, Keypad: step 8, image 1 of 1
    • Pry off circuit board with a flathead screwdriver.
  9. LG 1010 Keypad Replacement: step 9, image 1 of 1
    • Pull out flexible keypad.
Install new keypad and reassemble following these instructions in reverse order.
2 other people completed this guide.
Nicholas Schmidt
97 Reputation
7 Guides authored
Cal Poly, Team 3-25, Regan Fall 2010 Member of Cal Poly, Team 3-25, Regan Fall 2010
CPSU-REGAN-F10S3G25
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 9
All Time: 920
