Introduction
The problem could be due to a loose connection from the laptop monitor.
You will have dismantle the laptop to be able to reach into the connector.
Remove the 6 outer screws on the underside of the laptop.
Open the battery compartment and remove the 7 visible screws.
Pry the corners of the bezel at the base of the keyboard, pushing up until it loosens.
Carefully remove the ribbon connections of the keyboard, power button, and wifi button.
Disconnect and re-connect the white monitor ribbon located on the left side to make sure it seats tight in the connection.
Reassemble the laptop by following these steps in reverse.
The monitor should work when powered on again.
