Dell XPS 1340 CPU Fan Replacement
  1. Dell XPS 1340 CPU Fan Replacement, CPU Fan: step 1, image 1 of 1
    • Remove the battery by sliding the battery lock switch
  2. Dell XPS 1340 CPU Fan Replacement: step 2, image 1 of 1
    • Remove the lower panel of the laptop by loosening 10 screws. Note that the screws do no come out of the back panel.
  3. Dell XPS 1340 CPU Fan Replacement: step 3, image 1 of 1
    • Remove two screws which holds a smaller back panel covering only the heatsink
  4. Dell XPS 1340 CPU Fan Replacement: step 4, image 1 of 2 Dell XPS 1340 CPU Fan Replacement: step 4, image 2 of 2
    • Loosen the four screws on the heat sink for the CPU. Note that these screws don't come out.
    • Now carefully lift the unit from holding the heat pipe.
    • After the heat-pipe unit is removed, the power connector for the fan is accessible.
  5. Dell XPS 1340 CPU Fan Replacement: step 5, image 1 of 2 Dell XPS 1340 CPU Fan Replacement: step 5, image 2 of 2
    • First remove the power connector for the CPU Fan.
    • Now remove the two screws connecting the CPU Fan.
    • Slowly slide the CPU Fan upwards. It would be a little tight around the edges.
  6. Dell XPS 1340 CPU Fan Replacement: step 6, image 1 of 1
    • Unpack the new fan. Make sure the power wires are fixed in the hook provided.
    • Follow all step backwards and finish.
4 other people completed this guide.
Paras Tolani
188 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 15
All Time: 2,805
