How to Alarm Clock
  1. How to Alarm Clock, The issue: step 1, image 1 of 1
    • The Problem: here I should read 12:47
  2. How to Alarm Clock: step 2, image 1 of 2 How to Alarm Clock: step 2, image 2 of 2
    • After removing the 2 screws on the bottom, carefully open the bottom frame, see location of the plastic snaps snaps
  3. How to Alarm Clock: step 3, image 1 of 3 How to Alarm Clock: step 3, image 2 of 3 How to Alarm Clock: step 3, image 3 of 3
    • Removes the back panel, taking care of the other plastic snaps
    • The projector and its optics is shown in the blue square
  4. How to Alarm Clock, The optics: step 4, image 1 of 3 How to Alarm Clock, The optics: step 4, image 2 of 3 How to Alarm Clock, The optics: step 4, image 3 of 3
    • cables are tied together with a simple ribbon, in general the inner construction seems very cheap
    • The Projector is made of three parts:
    • A red LED
    • The display with its controller
    • the lens with focus mechanics
    • All parts are kept by tiny screws that you have to remove
    • Take extra caution when handling the display, the flat cable is very weak and can be damaged by improper handling
  5. How to Alarm Clock: step 5, image 1 of 3 How to Alarm Clock: step 5, image 2 of 3 How to Alarm Clock: step 5, image 3 of 3
    • Carefully remove display from its supporting frame
    • The issue should be ralated to flat cable connecting display to controller
  6. How to Alarm Clock: step 6, image 1 of 3 How to Alarm Clock: step 6, image 2 of 3 How to Alarm Clock: step 6, image 3 of 3
    • Verify that moving the flat the display returns to work
    • put a stiffner on controller side and close to the display
    • if everything is working, reassemble the clock by doing the steps in reverse order
  7. How to Alarm Clock: step 7, image 1 of 1
    • Problem solved.
Andrea Gangemi
172 Reputation
1 Guide authored
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 71
All Time: 12,681
