Introduction
Mountain and Road Light Merino T-Shirts series and Merino Hoody can be repaired with a technique = felting, which is a technique that sticks together the wool raw wool with a needle dedicated to felt with a return on the tip, to pierce holes that occur from broken threads and insect bites of Merino wool cut-and-sawed products such as Merino Hoody.
Wool (raw wool)
Felt needle
Sponge for felting
Soapy water (with 1-2 drops of detergent in a cup)
Tear the wool raw wool larger than the hole, lightly knead it by hand and put it together on the hole.If it seems to be enough to try to do the work, it is okay to add later.
Place the felting sponge down and stick it with a felt needle.
After lightly stabbing to secure the perimeter of the hole, it stabs it with a crunching toward the center. (Please refer to the video below for the sting force condition.)
As with the surface, the back side is also pierced with a needle.If you put soapy water on the floating raw hair and rub it with your finger, the raw hair will become familiar and it will be easier to become felt.
Repeat the front and back about 3-4 times and harden.
Once you have assimilated with the fabric to some extent, at the end let you familiarize with the repair point by rubbing it with your finger.
It is completed. When washing is repeated, felting progresses, and it becomes more durable.
To reassemble your device, perform these steps in reverse order.
Special thanks to these translators:
100%
Kuromi is helping us fix the world! Want to contribute?
Start translating ›
