Repair Loose Cable Plugs
    1. Repair Loose Cable Plugs, Sophon 15.6" Monitor: step 1, image 1 of 1
      • Insert wisdom here.
      Ask FixBot
    2. Repair Loose Cable Plugs: step 2, image 1 of 1
      • The cable connection plugs can come loose
      Ask FixBot
    3. Repair Loose Cable Plugs: step 3, image 1 of 1
      • Use a butter knife to separate top of screen from frame.
      Ask FixBot
    4. Repair Loose Cable Plugs: step 4, image 1 of 1
      • Clips that hold the screen to the frame.
      Ask FixBot
    5. Repair Loose Cable Plugs: step 5, image 1 of 1
      • Screen separated from frame.
      Ask FixBot
    6. Repair Loose Cable Plugs: step 6, image 1 of 1
      • Be careful of the cable in the top left corner, don't try to pull it loose.
      Ask FixBot
    7. Repair Loose Cable Plugs: step 7, image 1 of 1
      • Also be careful of the ribbon cable. Don't pull the screen too far from the frame.
      Ask FixBot
    8. Repair Loose Cable Plugs: step 8, image 1 of 1
      • One of the three screws that hold down the circuit board at the bottom right of the screen. The USB C and HDMI cables plug into this board.
      Ask FixBot
    9. Repair Loose Cable Plugs: step 9, image 1 of 1
      • Another of the three screws. The mounts of these screws are glued to the frame, and can come loose.
      Ask FixBot
    10. Repair Loose Cable Plugs: step 10, image 1 of 1
      • Use super glue to re-glue the mounts to the frame. Add additional super glue on top of mounts after glue dries.
      Ask FixBot
    11. Repair Loose Cable Plugs: step 11, image 1 of 1
      • Mix up some 5 minute epoxy.
      Ask FixBot
    12. Repair Loose Cable Plugs: step 12, image 1 of 1
      • Apply epoxy to screw mounts. You might want to apply some to the screw mounts on the left side circuit board as well.
      Ask FixBot
    13. Repair Loose Cable Plugs: step 13, image 1 of 1
      • Be careful in the future with these connections, as they are not super sturdy.
      • Snap the frame back onto the screen and plug it in!
      Ask FixBot
ScienceMagic
232 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 44
All Time: 127
