Reemplazo de tornillos Pentalobe de iPhone 6s
  1. Reemplazo de tornillos Pentalobe de iPhone 6s, Tornillos Pentalobe: step 1, image 1 of 1
    • Antes de desarmar su iPhone, descarga la batería por debajo del 25%. Una batería de litio-ion cargada puede generar fuego o explotar si es perforada accidentalmente.
    • Apaga tu iPhone antes de empezar a desarmar.
    • Remueve los dos tornillos Pentalobe P2 de 3.4 mm que se encuentran cerca del conector Lightning en el borde inferior de tu iPhone.
Para volver a armar tu dispositivo, sigue estas instrucciones en orden inverso.
39 other people completed this guide.
Special thanks to these translators:
en es
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Evan Noronha
223,523 Reputation
168 Guides authored
2 Comments
I noticed both my pentalobe screws wouldn’t screw in last time. Upon checking the little components that the screws fix into were loose inside. Not a major drama but they also seem to hold the charger cable in place… or at least I’ve noticed cables are loose on my iPhone 6 since then. Is there a part I can buy to fix this issue, does anyone know please?
justingrisbrook - Reply
I have an iPhone 6s plus, but I got a new phone recently so I put my 6s plus in my side table and went back to it a couple of weeks later just to see that the pentalobe screws are missing and the phone will no longer charge, I also realized that when I plug the charger in its a bit loose. There was also nothing wrong with the phone before it worked perfectly fine.
Simoneil Ming - Reply
Past 24 Hours: 8
Past 7 Days: 41
Past 30 Days: 163
All Time: 25,030
