Replacement or expansion RAM
  1. Replacement or expansion RAM, Battery: step 1, image 1 of 3 Replacement or expansion RAM, Battery: step 1, image 2 of 3 Replacement or expansion RAM, Battery: step 1, image 3 of 3
    • Unlock the battery latch on the right.
    • Unlock the battery lock on the left.
    • Remove the battery pack from its slot.
  2. Replacement or expansion RAM, Access to Components 2: step 2, image 1 of 3 Replacement or expansion RAM, Access to Components 2: step 2, image 2 of 3 Replacement or expansion RAM, Access to Components 2: step 2, image 3 of 3
    • Using the Philips # 0 screwdriver, unscrew the 2 screws of the top cover
    • Check the marks indicating the direction in which the cover must be removed.
    • Remove the bottom cover by removing it in the direction of the markers.
  3. Replacement or expansion RAM: step 3, image 1 of 1
    • Then appear the other components of the Laptop.
  4. Replacement or expansion RAM, RAM: step 4, image 1 of 3 Replacement or expansion RAM, RAM: step 4, image 2 of 3 Replacement or expansion RAM, RAM: step 4, image 3 of 3
    • Here is the RAM bar installed by default.
    • Locate and remove the spring blades that hold the memory module in place.
    • Remove the memory module (RAM).
  5. Replacement or expansion RAM: step 5, image 1 of 1
    • Here is the RAM bar out of its location.
To reassemble your device follow the instructions in reverse order
Special thanks to these translators:
fr en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,538 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 7
All Time: 357
