This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Introduction
pré requis uniquement (le guide complet pour enlever le bouton home comprend aussi le joint)
Enlevez les deux vis cruciformes Phillips #00 de 1,9 mm qui attachent le cache du bouton Home.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
9 other people completed this guide.
Special thanks to these translators:
81%
These translators are helping us fix the world! Want to contribute?
Start translating ›
One Comment
Home button robin cable malfunction after replaced.
Replaced broken Home button robin cable, now the phone will not turn on unless I unplug the home button cable from the mother board! I've thought of placing the phone in recovery mode and placing the phone in factory setting then trying to reconnect the cable, BUT to do that the home button has to be WORKINGand it's NOT working. Also the phone as the current iOS on it... Any ideas other than buying a new home button cable and trying the replacement again?
