Introduction
Ce tutoriel vous montre comment remplacer la prise jack.
Retirez la coque arrière en insérant un outil d'ouverture en plastique dans l'encoche sur le côté gauche du LG G4, puis en faisant délicatement levier.
Placez délicatement votre outil en plastique sous les trois nappes, là où elles sont connectées. Soulevez-les avec précaution pour détacher la nappe.
Pour remonter votre appareil, suivez les instructions en sens inverse.
7 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
8 Comments
My g4's headphone could only produce sound on one side. So i bought a new headphone jack from ebay and replaced it. The problem still persists. Does this mean it could be a motherboard issue?
Or a headphone issue. You did try a different pair of headphones?
i did the same as pholklorr with my g4 but bought oem and still doesn't work you can only hear it from one side
Great! My headphone port couldn't hold my headphones anymore because of wear & tear (they kept falling out) but this guide and a 6 dollar ebay-item fixed it! Thanks a lot.
