Replacement of the coin cell battery on the Dell XPS 13 9380
  1. Replacement of the coin cell battery on the Dell XPS 13 9380, Remove the back panel: step 1, image 1 of 3 Replacement of the coin cell battery on the Dell XPS 13 9380, Remove the back panel: step 1, image 2 of 3 Replacement of the coin cell battery on the Dell XPS 13 9380, Remove the back panel: step 1, image 3 of 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Torx T5 driver to unscrew the eight screws securing the back panel.
    • Use a spudger to pry up and loosen the back panel.
    • Lift the back panel up slightly from the non-hinged edge.
    • Pull the back panel away from the hinged edge, wiggling it back and forth to loosen the clips.
    • When the back panel clips are free, remove the back panel.
  2. Replacement of the coin cell battery on the Dell XPS 13 9380, Remove the battery: step 2, image 1 of 2 Replacement of the coin cell battery on the Dell XPS 13 9380, Remove the battery: step 2, image 2 of 2
    • Disconnect the cable from the battery by pulling the connector towards the battery.
    • Pull parallel to the battery, not straight up.
    • Remove the four screws (M2 x 2) securing the battery.
    • Remove the screw (M1.6 x 4) securing the battery.
    • Remove the battery from its recess.
  3. Replacement of the coin cell battery on the Dell XPS 13 9380, Coin cell battery: step 3, image 1 of 1
    • We removed or disconnected the battery to avoid any electrical discharge.
    • Removing the coin cell battery resets the BIOS settings to factory values. Before removing the coin cell battery, it is recommended to note the BIOS settings.
    • 1- Disconnect the coin cell battery cable from the motherboard
    • 2- Use a lever to remove the coin cell battery from the motherboard.
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
Schwarzer is helping us fix the world! Want to contribute?
Start translating ›
Schwarzer
4,844 Reputation
13 Guides authored
i.Fixit FR Team Member of i.Fixit FR Team
Community
3 Members
40 Guides authored
One Comment
Note to anyone replacing this, the model is a ML-1220 3V rechargeable coin cell battery, you will need one with a Dell compatible connector or to solder said connector to battery that comes with preinstalled solder tabs.
StereoTypo - Reply
Past 24 Hours: 1
Past 7 Days: 32
Past 30 Days: 127
All Time: 5,910
