Replacement the WiFi card on Dell XPS 12 9Q23
  1. Replacement the WiFi card on Dell XPS 12 9Q23, Battery: step 1, image 1 of 1
    • Pop the center cover open on the bottom cover.
    • Remove the center screw with a #00 Phillips screwdriver.
    • Use a T5 Torx screwdriver for the remaining screws around the edge of the bottom cover.
  2. Replacement the WiFi card on Dell XPS 12 9Q23: step 2, image 1 of 1
    • Carefully remove back panel after all screws have been removed.
  3. Replacement the WiFi card on Dell XPS 12 9Q23: step 3, image 1 of 1
    • After the back panel has been removed, disconnect the battery to prevent electrical shock
  4. Replacement the WiFi card on Dell XPS 12 9Q23: step 4, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the 8 screws that secure the battery.
  5. Replacement the WiFi card on Dell XPS 12 9Q23, Remove the battery: step 5, image 1 of 1
    • Once all the screws have been removed the battery is now safe to extract
  6. Replacement the WiFi card on Dell XPS 12 9Q23, Remove the WiFi card: step 6, image 1 of 3 Replacement the WiFi card on Dell XPS 12 9Q23, Remove the WiFi card: step 6, image 2 of 3 Replacement the WiFi card on Dell XPS 12 9Q23, Remove the WiFi card: step 6, image 3 of 3
    • We removed the battery to avoid electric shocks.
    • Disconnect the two wires from the WiFi card. You can do this with a pair of pliers or your fingernail.
    • Remove the screw with a #00 Phillips screwdriver.
    • Now remove your WiFi card to replace it.
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
Schwarzer is helping us fix the world! Want to contribute?
Start translating ›
Schwarzer
4,844 Reputation
13 Guides authored
i.Fixit FR Team Member of i.Fixit FR Team
Community
3 Members
40 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 470
