Introduction
Il est très simple d'accéder à la RAM.
Poussez avec les doigts les deux loquets de déverrouillage de la batterie et retirez celle-ci de l'ordinateur.
Retirez les trois vis identiques Phillips de 2 mm du capot de la mémoire.
Soulevez le capot suffisamment pour le saisir et retirez-le en le faisant glisser vers vous.
These screws are different from the rest, they should be kept separate from the others.
Concur, my screws were Phillips #0 as
Écartez simultanément les clips de chaque côté de la barrette de RAM. Ces clips maintiennent la barrette en place et lorsque vous les écartez, la barrette se débloque.
Tirez la barrette hors de son connecteur.
Pour remonter votre appareil, suivez les mêmes instructions dans l'ordre inverse.
222 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
One Comment
Really easy to install RAM on Macbook Pro 15'' Model A1226!!
I had 2GB of RAM (1GB and 1GB), so when I read this tutorial I decided to buy one ram of 2GB 667Mhz and It is working great (now I've got a total of 3 GB). I'm willing to install up to 6 GB with this same tutorial. Recommended!
Before start, make a clone of your old HD into the new one, if you don't want to initiate a fresh copy. (Carbon Copy software is good).
ColmillodeChile - Reply
Besides using WD 500GB models, are the WD 640GB and WD 750GB (the 9.5mm thickness model) good to go for? I am still considering as I have heard from other websites on the computer does not draw enough power to power up the 640 and 750 as it has the clicking sound and the rainbow keeps appearing. Anyone has install one before yet?
Please advice. Appreciated! Thanks a million to all the Mac gurus out there!
Danny Lim -
What is this about removing the PRAM battery causing a reinitialization of the HDD? For serious?
Adrian - Reply
No, that's nonsense
max damage -
Wait, I misunderstood you. I thought the comment was directed at the PRAM battery removal page. Silly me.
Nevermind. Yes, it is always a good idea to backup one's data before doing stuff like this. I never do, and have never had any problems, but it's still a good idea.
Adrian - Reply
The two screws removed in step 3 should not be mixed with screws in steps 5 through 7. Though similar, they are actually slightly shorter and have a bigger head. If you put the longer screws back in here when reassembling, the button to unlatch the top will not work properly.
Doug - Reply
I think you may have commented on the wrong page. This page only has 3 steps, and the screws are removed in step 2, not 3.
(MacBook Pro 15" Core 2 Duo Models A1226 and A1260 RAM Replacement)
Don - Reply
I'm not sure how the user notes get attached to the various procedures here, but my comment does seem to show up properly when viewing the steps for Hard Drive Replacement. However, the number of the step may be off if viewed as part of another procedure.
Doug - Reply
