LCD screen Replacement
  1. LCD screen Replacement, Battery: step 1, image 1 of 3 LCD screen Replacement, Battery: step 1, image 2 of 3 LCD screen Replacement, Battery: step 1, image 3 of 3
    • Unlock the battery latch on the right.
    • Unlock the battery lock on the left.
    • Remove the battery pack from its slot.
  2. LCD screen Replacement, LCD screen: step 2, image 1 of 3 LCD screen Replacement, LCD screen: step 2, image 2 of 3 LCD screen Replacement, LCD screen: step 2, image 3 of 3
    • Gently insert the fingernail between the screen frame and the screen glass.
    • De-clipping one by one the fixing points of the frame surrounding the LCD screen
  3. LCD screen Replacement: step 3, image 1 of 3 LCD screen Replacement: step 3, image 2 of 3 LCD screen Replacement: step 3, image 3 of 3
    • Completely detach the frame surrounding the LCD screen.
    • Mark the 2 upper fixing screws of the LCD screen. Unscrew them.
    • Mark the two lower fixing screws on the LCD screen. Unscrew them.
  4. LCD screen Replacement: step 4, image 1 of 3 LCD screen Replacement: step 4, image 2 of 3 LCD screen Replacement: step 4, image 3 of 3
    • Gently lay the LCD screen on the keyboard.
    • Locate the connector on the LCD screen
    • Release the connection cable.
  5. LCD screen Replacement: step 5, image 1 of 2 LCD screen Replacement: step 5, image 2 of 2
    • Remove the connector.
    • Once the connector is removed, completely remove the LCD screen.
To reassemble your device follow the following instructions in reverse order
Special thanks to these translators:
fr en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
30,908 Reputation
264 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 37
Past 30 Days: 118
All Time: 4,357
