Logitech z-5500 LCD Screen Replacement
  1. Logitech z-5500 LCD Screen Replacement, Disassembling the housing: step 1, image 1 of 2 Logitech z-5500 LCD Screen Replacement, Disassembling the housing: step 1, image 2 of 2
    • Remove the stand by unscrewing the two screws with a #3 Hexagon driver.
    • Remove the 4 screws, one from each corner of the case, with a Phillips #2 screwdriver.
  2. Logitech z-5500 LCD Screen Replacement, Opening the Housing: step 2, image 1 of 2 Logitech z-5500 LCD Screen Replacement, Opening the Housing: step 2, image 2 of 2
    • Remove the volume button on the front of the pod. It may be a little difficult to pull off because it is lightly glued.
    • Separate the two sides by removing the two pieces (black and gray). They are clipped in 3 different places.
    • Be careful not to use too much force (horizontally), as some legs can be quite fragile, like that of the power button.
  3. Logitech z-5500 LCD Screen Replacement, Remove the Display: step 3, image 1 of 3 Logitech z-5500 LCD Screen Replacement, Remove the Display: step 3, image 2 of 3 Logitech z-5500 LCD Screen Replacement, Remove the Display: step 3, image 3 of 3
    • Remove the 4 screws with a Phillips #2 screwdriver.
    • It will be necessary to desolder all the wires in the ribbon cable more or less at the same time. You can also simply cut the end of the ribbon cable and strip the individual wires.
    • Note how the wires are soldered, it's neat.
    • Clean the wires so that they are not too thick. (we can do much better than in the photo!)
  4. Logitech z-5500 LCD Screen Replacement, Solder the New Display: step 4, image 1 of 2 Logitech z-5500 LCD Screen Replacement, Solder the New Display: step 4, image 2 of 2
    • To ensure a good connection between the wires and the circuit board, treat the copper pads with flux first, then tin them with a light coating of solder. Apply the solder sparingly so you don't accidentally fill the hole.
    • Position the wires in the holes, and bend them upwards to make soldering a little easier.
    • My soldering is quite disgusting, but there is no contact between the wires, that's the main thing! Check yours carefully!
  5. Logitech z-5500 LCD Screen Replacement, Reassembly: step 5, image 1 of 1
    • Take this opportunity to clean the dust and the inside of the screen glass! ;)
    • Reassemble the case, plug it in, and enjoy a brand new display! Here we go again for 10 years!
    Can't find the display anywhere in the world ALiexpress & ALiexpress is not shipping to my country India, because our gov banned imports from Aliexpress. I tried finding it on eBay & Amazon but no luck.
    Sush - Reply
To reassemble your device, follow the instructions in reverse order.
5 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Nicolas Cambas
265 Reputation
1 Guide authored
2 Comments
Tuto très bien fait !
Très facile à réaliser en sachant qu’il n’y a pas de mauvaise surprise de fixations ou câbles collés. Merci !!!
Ceci étant, on ne trouve l’écran plus qu’ici :
https://fr.aliexpress.com/item/189448119...
https://fr.aliexpress.com/item/100500333...
sebastien_bachene - Reply
Un très bon tuto, bonne réalisation
jpmoureau@sfr.fr - Reply
Past 24 Hours: 9
Past 7 Days: 32
Past 30 Days: 146
All Time: 4,500
