Removing the HP Elitebook 6930p RTC (CMOS) Battery
  1. Removing the HP Elitebook 6930p RTC (CMOS) Battery, Battery Removal: step 1, image 1 of 3 Removing the HP Elitebook 6930p RTC (CMOS) Battery, Battery Removal: step 1, image 2 of 3 Removing the HP Elitebook 6930p RTC (CMOS) Battery, Battery Removal: step 1, image 3 of 3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p RTC (CMOS) Battery, Keyboard: step 2, image 1 of 3 Removing the HP Elitebook 6930p RTC (CMOS) Battery, Keyboard: step 2, image 2 of 3 Removing the HP Elitebook 6930p RTC (CMOS) Battery, Keyboard: step 2, image 3 of 3
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing the HP Elitebook 6930p RTC (CMOS) Battery: step 3, image 1 of 3 Removing the HP Elitebook 6930p RTC (CMOS) Battery: step 3, image 2 of 3 Removing the HP Elitebook 6930p RTC (CMOS) Battery: step 3, image 3 of 3
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
  4. Removing the HP Elitebook 6930p RTC (CMOS) Battery: step 4, image 1 of 3 Removing the HP Elitebook 6930p RTC (CMOS) Battery: step 4, image 2 of 3 Removing the HP Elitebook 6930p RTC (CMOS) Battery: step 4, image 3 of 3
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
  5. Removing the HP Elitebook 6930p RTC (CMOS) Battery, RTC (CMOS) Battery: step 5, image 1 of 2 Removing the HP Elitebook 6930p RTC (CMOS) Battery, RTC (CMOS) Battery: step 5, image 2 of 2
    • Locate the the battery
    • If the battery wires are running underneath the WLAN module you will have to remove it first. In my case it was necessary to remove the WLAN module.
    • Disconnect the battery from the connector
    • Removal of this battery will not clear a BIOS password on the HP Elitebook 6930P and some other Business Class notebooks.
    • Gently un-clip the battery from the plastic housing to completely remove it from the laptop
10 other people completed this guide.
Richdave
32,081 Reputation
30 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,535 Guides authored
8 Comments
This did not work for me. I left the CMOS battery disconnected for a day.
You need to contact HP to get this resolved.
http://h30434.www3.hp.com/t5/Notebook-Op...
Wm Brian Savacool - Reply
This didn't work for me
Depinder Bharti - Reply
I can't even boot
Hugo Escobar - Reply
cool i like the explanation
Nartey Levis - Reply
Τελικά μπορούμε με κάποιο τρόπο να αφαιρέσουμε κωδικό πρόσβασης BIOS για την HP EliteBook 6930p????
Αν όχι μήπως θα λειτουργούσε ένας δίσκος λειτουργικού γραμμένος από ένα άλλο HP EliteBook 6930p ώστε να μην χρειαστούμε πρόσβασης BIOS?????
ΠΑΝΑΓΙΩΤΗΣ ΓΙΑΝΝΑΚΑΚΗΣ - Reply
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 96
All Time: 40,873
