Removing the HP Elitebook 6930p Keyboard
  1. Removing the HP Elitebook 6930p Keyboard, Battery Removal: step 1, image 1 of 3 Removing the HP Elitebook 6930p Keyboard, Battery Removal: step 1, image 2 of 3 Removing the HP Elitebook 6930p Keyboard, Battery Removal: step 1, image 3 of 3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p Keyboard, Keyboard: step 2, image 1 of 3 Removing the HP Elitebook 6930p Keyboard, Keyboard: step 2, image 2 of 3 Removing the HP Elitebook 6930p Keyboard, Keyboard: step 2, image 3 of 3
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing the HP Elitebook 6930p Keyboard: step 3, image 1 of 3 Removing the HP Elitebook 6930p Keyboard: step 3, image 2 of 3 Removing the HP Elitebook 6930p Keyboard: step 3, image 3 of 3
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
  4. Removing the HP Elitebook 6930p Keyboard: step 4, image 1 of 3 Removing the HP Elitebook 6930p Keyboard: step 4, image 2 of 3 Removing the HP Elitebook 6930p Keyboard: step 4, image 3 of 3
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
Richdave
32,108 Reputation
30 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,541 Guides authored
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 31
All Time: 10,543
