Removing the HP Elitebook 6930p Hard Drive
  1. Removing the HP Elitebook 6930p Hard Drive, Battery Removal: step 1, image 1 of 3 Removing the HP Elitebook 6930p Hard Drive, Battery Removal: step 1, image 2 of 3 Removing the HP Elitebook 6930p Hard Drive, Battery Removal: step 1, image 3 of 3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p Hard Drive, Hard Drive: step 2, image 1 of 3 Removing the HP Elitebook 6930p Hard Drive, Hard Drive: step 2, image 2 of 3 Removing the HP Elitebook 6930p Hard Drive, Hard Drive: step 2, image 3 of 3
    • With the bottom of the laptop facing up and the front toward you locate and loosen the two M2.0×5.0 captive screws holding the hard drive bay cover closed.
    • Lift the left side of the bay cover and swing it up and to the right to remove it.
    • Loosen the M2.5×10.0 captive screw that holds the hard drive in.
    • Grasp the plastic tab and slide the hard drive to the right to disconnect it from the motherboard.
    • Lift the hard drive straight up and out of the laptop.
  3. Removing the HP Elitebook 6930p Hard Drive: step 3, image 1 of 2 Removing the HP Elitebook 6930p Hard Drive: step 3, image 2 of 2
    • To remove the hard drive from the bracket remove the two M3.0×4.0 screws from each side of the hard drive.
Richdave
32,150 Reputation
30 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,465 Guides authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 28
All Time: 9,689
