Removing the Cover From the Printer
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Removing the Cover From the Printer, Top Cover: step 1, image 1 of 1
      • Remove the back two 14.0 mm Torx #10 screws.
      Ask FixBot
    2. Removing the Cover From the Printer: step 2, image 1 of 1
      • Lay the printer on its back.
      • Grab the paper tray by its right side and pull it to the left and up.
      Ask FixBot
    3. Removing the Cover From the Printer: step 3, image 1 of 1
      • Open the frontal access panel by lifting it from the top.
      • Similar to the paper tray, grab it from the right side and pull it to the left and up.
      Ask FixBot
    4. Removing the Cover From the Printer: step 4, image 1 of 3 Removing the Cover From the Printer: step 4, image 2 of 3 Removing the Cover From the Printer: step 4, image 3 of 3
      • Take out the two frontal 14.0 mm Torx #10 screws.
      • Carefully lift the frontal cover.
      • Don't lift it up aggressively. A strip will be attached to it.
      Ask FixBot
Justin Taiki Fukada
912 Reputation
7 Guides authored
Cal Poly, Team 1-41, Maness Winter 2014 Member of Cal Poly, Team 1-41, Maness Winter 2014
CPSU-MANESS-W14S1G41
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 236
