Removing a stuck Sterwins trimmer head
  1. Removing a stuck Sterwins trimmer head, Work safely!: step 1, image 1 of 1
    • Place the lower part of your unit on a flat surface for safe working.
    • Wear gloves!
  2. Removing a stuck Sterwins trimmer head, Removing the axle from the cutting head.: step 2, image 1 of 1
    • Remove the two Torx T30 screws.
    • Note the screw locations.
  3. Removing a stuck Sterwins trimmer head, Removing the lower tube: step 3, image 1 of 1
    • You can now disconnect the lower tube from the cutting head.
    • Clamp the axle in a vise.
    • Rotate the head so that the head and cutting assembly can be disassembled.
    • Careful, it's an inverted step! "But, Corentin, why is it an inverted step?" It's to prevent untimely and dangerous loosening!
  4. Removing a stuck Sterwins trimmer head, Reposition the loosening washer: step 5, image 1 of 2 Removing a stuck Sterwins trimmer head, Reposition the loosening washer: step 5, image 2 of 2
    • Now that you've saved your device, don't forget to put the washer back on!
    • Tighten the two Torx T30 screws to secure the bottom section and the tube.
Finally, add the "loosening" washer to avoid anything getting stuck again.
2 other people completed this guide.
Special thanks to these translators:
fr en
100%
shingle is helping us fix the world! Want to contribute?
Start translating ›
Corentin Kezadri
304 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 39
Past 7 Days: 209
Past 30 Days: 989
All Time: 7,070
