Repairing Keyboard - removing numerical keypad
  1. Repairing Keyboard - removing numerical keypad, removing numerical keypad: step 1, image 1 of 1
    • You can do this with most keyboards. I had an older Dell keyboard model L100.
  2. Repairing Keyboard - removing numerical keypad: step 2, image 1 of 1
    • Turn the keyboard over and you will see 15 screws. Remove them.
  3. Repairing Keyboard - removing numerical keypad: step 3, image 1 of 1
    • Take the keyboard apart. You will find a white rubber sheet under the top part of the keyboard. Cut off the part for the numerical keypad.
  4. Repairing Keyboard - removing numerical keypad: step 4, image 1 of 1
    • Fasten the top part of the keyboard and take the hacksaw to it. Cut off the numerical keypad part. Do not use power tools because you may produce toxic fumes and even activate fire alarm.
  5. Repairing Keyboard - removing numerical keypad: step 5, image 1 of 1
    • On the bottom part of the keyboard, remove the three screws and the metal bar holding the keyboard PCB and fold the plastic sheet so it is out of your way when cutting.
  6. Repairing Keyboard - removing numerical keypad: step 6, image 1 of 1
    • Now mark the bottom part of the keyboard for another cut.
  7. Repairing Keyboard - removing numerical keypad: step 7, image 1 of 1
    • Cut the bottom part of the keyboard too. Fold or remove the plastic PCB out of the way when cutting.
  8. Repairing Keyboard - removing numerical keypad: step 8, image 1 of 1
    • Screw the PCB and the metal bar back on.
  9. Repairing Keyboard - removing numerical keypad: step 9, image 1 of 1
    • Assemble the rest of the keyboard, and fold the plastic sheet under your keyboard. Do not cut it because it will render the keyboard useless.
  10. Repairing Keyboard - removing numerical keypad: step 10, image 1 of 1
    • Since you have cut the portion of the keyboard with the supporting leg for tilting, supply it with a new leg. You can use a key from the numerical keypad.
  11. Repairing Keyboard - removing numerical keypad: step 11, image 1 of 1
    • Tape the key to the keyboad
  12. Repairing Keyboard - removing numerical keypad: step 12, image 1 of 1
    • Presto, you are proud owner of a very geeky looking keyboard with even a piece of the PCB sticking out.
Stanko Vuleta
242 Reputation
1 Guide authored
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 97
All Time: 11,190
