Tools
Parts
No parts required.
Unscrew cap from air valve.
Use a thin object to press down the pin in the center of the valve, releasing the air in the tire.
Take a tire lever, and wedge it between the tire and the rim. Make sure the end scoops inward to grab the tire.
Once you manage to grab the edge of the tire with the lever, pull the lever back to scoop the tire out of the rim.
Then, use the notch in the other end of the lever to keep it steadily anchored on a nearby spoke.
