Motorola V60i Back Plate Replacement
  1. Motorola V60i Back Plate Replacement, Battery: step 1, image 1 of 2 Motorola V60i Back Plate Replacement, Battery: step 1, image 2 of 2
    • Flip the phone over so the back cover is facing up.
    • Using either a finger or a spudger, press the button located near the top of the phone by the antenna.
  2. Motorola V60i Back Plate Replacement: step 2, image 1 of 2 Motorola V60i Back Plate Replacement: step 2, image 2 of 2
    • Pry up the back plate from the phone.
    • Push the button near the bottom of the battery using either your finger or the spudger to release the battery.
  3. Motorola V60i Back Plate Replacement, Back Plate: step 3, image 1 of 1
    • Using a T6 Torx screwdriver, remove the four screws from the back of the phone.
  4. Motorola V60i Back Plate Replacement: step 4, image 1 of 2 Motorola V60i Back Plate Replacement: step 4, image 2 of 2
    • Simultaneously press the highlighted buttons on both sides of phone.
  5. Motorola V60i Back Plate Replacement: step 5, image 1 of 1
    • Separate the back plate from the rest of phone.
    • Do not pull the wire connecting the front and back plates.
Elizabeth OBrien
43 Reputation
7 Guides authored
Cal Poly, Team 30-40, Garner Spring 2010 Member of Cal Poly, Team 30-40, Garner Spring 2010
CPSU-GARNER-S10S30G40
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 3,539
