Introduction
This guide shows you how to remove the bottom cover beneath the battery, which is needed to strip down to the mid-layer of the device, which is needed for the USB board replacement guide.
Make sure the display is closed. Then, flip the computer over so that you can see the bottom cover.
Loosen the two 5 mm Phillips #0 on the upper edge of the cover.
Remove the three 5mm Phillips #0 screws that keep the battery connected to the computer.
The model device did not come with a hard drive. However, you will need to remove the hard drive to proceed. Please remove the hard drive following the steps on page 16 of the official Dell Inspiron 15-7537 manual.
Completely unscrew the 2 mm screw that connects the WiFi card to the mother board using a Philips head screwdriver.
Remove the single 5mm screw that connects the keyboard to the palm assembly with the Phillips head screwdriver.
Unscrew the two black 5 mm screws underneath the keyboard using a Phillips head screwdriver.
