Removing Dell Inspiron 1150 Optical drive
  1. Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Battery: step 1, image 1 of 3 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Battery: step 1, image 2 of 3 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Battery: step 1, image 3 of 3
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Palm Rest: step 2, image 1 of 2 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Palm Rest: step 2, image 2 of 2
    • Position the computer upside down.
    • Remove the twelve M2.5 x 8-mm screws.
    • Remove the M2.5 x 4-mm screw from the battery bay
  3. Removing Dell Inspiron 1150 Optical drive: step 3, image 1 of 2 Removing Dell Inspiron 1150 Optical drive: step 3, image 2 of 2
    • Position the computer keyboard side up.
    • Remove the two M2.5 x 5-mm screws from the top of the palm rest.
    • Disconnect the mouse pad cable from the main board.
    • Separate the palm rest from the base by lifting its inside edge. Start at the back center.
    • Be careful to avoid damaging the palm rest while separating it from the base.
  4. Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Optical drive: step 4, image 1 of 3 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Optical drive: step 4, image 2 of 3 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Optical drive: step 4, image 3 of 3
    • Locate the optical disk drive on the bottom left hand side of the laptop.
    • Remove the single screw holding the optical disk drive in the chassis.
    • Remove the optical disk drive by gently pulling on the outer edge.
Daniel
87 Reputation
2 Guides authored
Cal Poly, Team 16-2, Maness Spring 2010 Member of Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 Members
9 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 5,887
