Removing Bottom of iMac G4 15" 700 MHz EMC 1873
  1. Removing Bottom of iMac G4 15" 700 MHz EMC 1873, Outer Base Plate: step 1, image 1 of 2 Removing Bottom of iMac G4 15" 700 MHz EMC 1873, Outer Base Plate: step 1, image 2 of 2
    • Place the computer monitor face down on a safe, harmless surface.
    • Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
  2. Removing Bottom of iMac G4 15" 700 MHz EMC 1873: step 2, image 1 of 1
    • Remove the metal plate from bottom of the iMac G4.
    • The four screws do not completely separate from the metal plate.
  3. Removing Bottom of iMac G4 15" 700 MHz EMC 1873, RAM DIMM: step 3, image 1 of 2 Removing Bottom of iMac G4 15" 700 MHz EMC 1873, RAM DIMM: step 3, image 2 of 2
    • Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
    • These tabs lock the module in place and releasing them will cause the module to "pop" up.
    • Remove the RAM module from the iMac.
  4. Removing Bottom of iMac G4 15" 700 MHz EMC 1873, AirPort Card: step 4, image 1 of 1
    • Use a spudger to lift and remove the AirPort's antenna connector.
    • This step is only applicable to iMacs that came with an AirPort card installed.
  5. Removing Bottom of iMac G4 15" 700 MHz EMC 1873, Removing the Lower Case: step 5, image 1 of 1
    • Remove the four 28.07mm Torx #15 screws from the lower case.
  6. Removing Bottom of iMac G4 15" 700 MHz EMC 1873: step 6, image 1 of 2 Removing Bottom of iMac G4 15" 700 MHz EMC 1873: step 6, image 2 of 2
    • Open the base by carefully pulling straight off, do not rotate the cover.
    • Open slowly to ensure that no cables are damaged or disconnected.
  7. Removing Bottom of iMac G4 15" 700 MHz EMC 1873: step 7, image 1 of 1
    • Squeeze the small black tab and wiggle gently to remove the colored power cable.
    • Do not pull directly on the colored wires.
    • Do not remove black grounding wire.
  8. Removing Bottom of iMac G4 15" 700 MHz EMC 1873: step 8, image 1 of 1
    • Grab both sides of the blue connector and firmly pull to remove it from the mother board.
    • Do not pull directly on the ribbon cable.
Elliot Freerks
896 Reputation
3 Guides authored
Cal Poly, Team 5-32, Amido Fall 2011 Member of Cal Poly, Team 5-32, Amido Fall 2011
CPSU-AMIDO-F11S5G32
4 Members
8 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 36
All Time: 6,353
