Removing 2005-2007 Ford Focus Front Wheel
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Removing 2005-2007 Ford Focus Front Wheel, Front Wheel: step 1, image 1 of 1
    • Put the car in park (automatic) or neutral (manual).
    • Apply the parking brake.
    • Place chocks behind the rear wheels.
  2. Removing 2005-2007 Ford Focus Front Wheel: step 2, image 1 of 1
    • Use a 19 mm lug wrench to loosen each lug nut a half turn.
  3. Removing 2005-2007 Ford Focus Front Wheel: step 3, image 1 of 2 Removing 2005-2007 Ford Focus Front Wheel: step 3, image 2 of 2
    • Use a hydraulic jack on the car's frame to jack the car.
    • A small notch shows where to place the jack.
    • It is only necessary to jack the car until the wheel no longer touches the ground.
  4. Removing 2005-2007 Ford Focus Front Wheel: step 4, image 1 of 1
    • Place a jack stand on the frame and remove the jack.
    • Never work on or underneath a car that is only supported by a jack. The car may fall, causing serious injury, or even death.
  5. Removing 2005-2007 Ford Focus Front Wheel: step 5, image 1 of 2 Removing 2005-2007 Ford Focus Front Wheel: step 5, image 2 of 2
    • Use a lug wrench to completely remove the four lug nuts.
    • Remove the wheel.
David Hodson
150,694 Reputation
127 Guides authored
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 18
All Time: 2,061
