Zerotow Remote
  1. Zerotow Remote, Remove screws: step 1, image 1 of 2 Zerotow Remote, Remove screws: step 1, image 2 of 2
    • Remove the screws from the perimeter of the remote.
    • Remove the Screws under the buttons first
  2. Zerotow Remote, Seperate the top cover from the handle assembly: step 2, image 1 of 3 Zerotow Remote, Seperate the top cover from the handle assembly: step 2, image 2 of 3 Zerotow Remote, Seperate the top cover from the handle assembly: step 2, image 3 of 3
    • Use a knife blade or thin scraper to gently separate the cover from the handle assembly.
    • Work slowly around the perimeter until the the cover is free
    • The cables that connect the top cover to the handle are very short. do separate with uncontrolled force otherwise you will break the cables.
  3. Zerotow Remote, Remove battery connector: step 3, image 1 of 3 Zerotow Remote, Remove battery connector: step 3, image 2 of 3 Zerotow Remote, Remove battery connector: step 3, image 3 of 3
    • Gently lift the bottom of the cover
    • With tweezers remove the power plug to the remote. This has the red and black wires to it.
  4. Zerotow Remote, Remove the wireless charger connector: step 4, image 1 of 2 Zerotow Remote, Remove the wireless charger connector: step 4, image 2 of 2
    • Use tweezers to remove the wireless charger connector. This is a USB micro connector and is very fragile.
  5. Zerotow Remote, Opening.: step 5, image 1 of 2 Zerotow Remote, Opening.: step 5, image 2 of 2
    • The screen can now be opened as shown
  6. Zerotow Remote, Reassembly: step 6, image 1 of 1
    • Use a syringe with a blunt tip to apply a thin bead of silicone grease to O-ring on the screen.
    • If you do not have a syringe you can use tooth pick or the tweezers to apply the grease.
    • Alternatively you can apply the grease to the handle side of the the remote
  7. Zerotow Remote, Reassembly - Connectors: step 7, image 1 of 2 Zerotow Remote, Reassembly - Connectors: step 7, image 2 of 2
    • Connect the cables as shown
    • On the handle side align the power and charging cables to be as close as possible to their sockets
    • Close the lid and use the tweezer to plug in the power cable first, and then the USB
    • The USB is quite tricky to get in, take your time.
  8. Zerotow Remote, Pinched cables: step 8, image 1 of 1
    • Once everything is connected, lift up each side of the screen to make sure no cables are going to be pinched.
    • Use tweezers to rearrange the cables if any look like they will be pinched
  9. Zerotow Remote, Check functionality: step 9, image 1 of 1
    • Check all of the remote functionality before screwing it together
    • Wireless charging - Blue light turns on when on the charger
    • Throttle works and calibrates
    • Remote GPS works - leave outside for 10 mins and you should see 10+ satellites.
    • Range check to Boogie - greater than 25 meters
  10. Zerotow Remote, Screw together the cover to the handle: step 10, image 1 of 1
    • Check again for no pinched cables
    • Start with the underside screws first, then the two on the front
    • Loosly tighten all the screws in the remote
    • work your way around the remote, tighten the screws a little bit more each time. Do not apply too much force as the screws can strip out the plastic easily.
    • Submerge the remote in FRESH water for 30 mins to ensure there is no leaks before use in salt water.
Finish Line
Mark Duyvesteyn
603 Reputation
5 Guides authored
1 Guide Comment
Very clear with great photos. Many thanks.
John Griff - Reply Share
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 35
All Time: 35
