Reformat SD Card
  1. Reformat SD Card, Reformat SD Card: step 1, image 1 of 2 Reformat SD Card, Reformat SD Card: step 1, image 2 of 2
    • Turn the camera on by sliding the switch from the "Off" position to the "On" position. The switch is located above the touchscreen and to the left.
    • The screen will say "Sensor cleaning" once the switch is moved to "On".
    Ask FixBot
  2. Reformat SD Card: step 2, image 1 of 1
    • Push the black button that says "Menu", located below the "ON/OFF" switch.
    Ask FixBot
  3. Reformat SD Card: step 3, image 1 of 1
    • Using the thumb pad, scroll to the 9th menu from the left.
    Ask FixBot
  4. Reformat SD Card: step 4, image 1 of 1
    • Scroll down the list using the thumb pad and select, "Format card" by pressing the center of the thumb pad labeled, "SET".
    Ask FixBot
  5. Reformat SD Card: step 5, image 1 of 2 Reformat SD Card: step 5, image 2 of 2
    • Once you select "OK", all pictures will be erased from the SD Card.
    • Press the right side of the thumb pad to move over the "Ok" button.
    • Once "OK" is highlighted, press the middle of thumb pad to initiate the formatting of the card.
    Ask FixBot
  6. Reformat SD Card: step 6, image 1 of 1
    • Wait.
    Ask FixBot
  7. Reformat SD Card: step 7, image 1 of 1
    • SD Card is now formatted.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 43
All Time: 1,394
