Introduction
Partial / tactical teardown, for cleaning and quick repair.
Face lens down, (front on table)
Remove 3 screws on the lens mount
Remove lens mount
Pull / push trpod mount towards back of the lens, and remove it. Be patient, it is very precisely assembled.
Loosen tripod ring, till it can rotate.
Remove tripod ring. Be aware, the is a 90 degree stepping steel ball inside.
Rotate the rear half of the lens, towards close-up direction (CW as looking downwards), pass 8m/25 feet mark and continue, while applying gentle force pulling rear part up, until they separate, mark the point.
When assemble them back, attach from this angle/point.
This is just a partial tear down. This lens is extremely well made, and very very precise.
Until this point, this is a reasonable "maintenance teardown". And you can do most mirror and lens cleaning and grease replace.
Putting them back from the point/angle you marked in previous step, the focus scale does not need a calibration.
4 other people completed this guide.
2 Comments
I am looking for more understanding of this breakdown. I have questions about the fragility of the components and how to clean the interior of the front glass of mold spores. Additionally i would love to understand how to calibrate its focus. Can you advise?
This is a professional lens, built very tough. Primary mirror cleaning is quite easy. but front element is kind of tricky. because there’s an inner thread there covered by damping oil/grease. Maybe you should try remove it from the front. remove the filter/cap thread ring first(My cap used to stuck with this ring so I‘ve got this far)…
In step 3, there are 2+3 screw holes at each end , those are for focus ring stopping screws. 3 for inf end and 2 for close end (if my memory is correct). But this is for adjustment instead of “calibration“. By my guess a giant lens like this could never be calibrated due to the TCE of aluminium tube. that’s why the focus ring is allow to go beyond inf.
Terrance -
