This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Redmi 9T 4G Battery Replacement
    1. Redmi 9T 4G Battery Replacement, Remove the back cover: step 1, image 1 of 1
      • Extract the SIM and its tray. There is no adhesive on the edges of the back cover, only clips. Insert a prying tool starting from the SIM side, not the power button side, as the fingerprint reader cable is located there, as shown in the photos.
      • Then, continue along all the edges of the smartphone.
      • If the rubber seal that holds the power button and fingerprint reader in place comes off, pay attention to the two guides and insert the two holes there to lock it in the correct position.
      Ask FixBot
    2. Redmi 9T 4G Battery Replacement: step 2, image 1 of 1
      • Unscrew all the green screws and remove the plastic cover.
      Ask FixBot
    3. Redmi 9T 4G Battery Replacement: step 3, image 1 of 2 Redmi 9T 4G Battery Replacement: step 3, image 2 of 2
      • Disconnect the battery cable on the right first, and then the fingerprint cable indicated by the arrow.
      Ask FixBot
    4. Redmi 9T 4G Battery Replacement: step 4, image 1 of 1
      • Lift the two adhesive strips on the sides and use the "B" adhesive tab to help lift the battery.
      • In my case, they snapped, so I had to remove the battery by prying it out.
      • After removing the battery, since the new one had the same clear adhesive, I removed the adhesive that was left on the phone chassis under the old battery.
      • Install the new battery and reassemble everything by following the steps in reverse.
      Ask FixBot
Matteo
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 56
Past 30 Days: 187
All Time: 433
