RedOctane X-Plorer Motherboard Replacement
  1. RedOctane X-Plorer Motherboard Replacement, Rear Case: step 1, image 1 of 2 RedOctane X-Plorer Motherboard Replacement, Rear Case: step 1, image 2 of 2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Motherboard Replacement: step 2, image 1 of 3 RedOctane X-Plorer Motherboard Replacement: step 2, image 2 of 3 RedOctane X-Plorer Motherboard Replacement: step 2, image 3 of 3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Motherboard Replacement: step 3, image 1 of 3 RedOctane X-Plorer Motherboard Replacement: step 3, image 2 of 3 RedOctane X-Plorer Motherboard Replacement: step 3, image 3 of 3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Motherboard Replacement, Auxiliary Port: step 4, image 1 of 3 RedOctane X-Plorer Motherboard Replacement, Auxiliary Port: step 4, image 2 of 3 RedOctane X-Plorer Motherboard Replacement, Auxiliary Port: step 4, image 3 of 3
    • Remove the two 10mm Phillips #1 screws from the auxiliary port board using a screwdriver.
    • Gently lift up on the auxiliary port to remove it from the case.
  5. RedOctane X-Plorer Motherboard Replacement, RJ-14 Connector: step 5, image 1 of 3 RedOctane X-Plorer Motherboard Replacement, RJ-14 Connector: step 5, image 2 of 3 RedOctane X-Plorer Motherboard Replacement, RJ-14 Connector: step 5, image 3 of 3
    • Remove the two 10mm Phillips #1 screws from the RJ-14 connector board.
    • Lift the RJ-14 connector to remove it from the case.
  6. RedOctane X-Plorer Motherboard Replacement, Keys: step 6, image 1 of 3 RedOctane X-Plorer Motherboard Replacement, Keys: step 6, image 2 of 3 RedOctane X-Plorer Motherboard Replacement, Keys: step 6, image 3 of 3
    • Use a screwdriver to remove the 10 mm Phillips #1 screws from the key sensor board.
    • Lift up on the key sensor board to remove it from the guitar neck.
    • When using the screwdriver, make sure to avoid puncturing the wires.
  7. RedOctane X-Plorer Motherboard Replacement: step 7, image 1 of 1
    • Using your fingers, remove the rubber pad to expose the colored keys.
  8. RedOctane X-Plorer Motherboard Replacement: step 8, image 1 of 2 RedOctane X-Plorer Motherboard Replacement: step 8, image 2 of 2
    • Reach one finger under the guitar to push the key out of the casing.
    • Repeat this step for the four remaining keys.
  9. RedOctane X-Plorer Motherboard Replacement, Strum Bar Sensor Board: step 9, image 1 of 3 RedOctane X-Plorer Motherboard Replacement, Strum Bar Sensor Board: step 9, image 2 of 3 RedOctane X-Plorer Motherboard Replacement, Strum Bar Sensor Board: step 9, image 3 of 3
    • Use a screwdriver to remove the four 14mm Phillips #1 screws around the perimeter of the strum bar sensor board.
    • Lift up on the strum bar sensor board to remove it from the case.
  10. RedOctane X-Plorer Motherboard Replacement, Whammy Bar Sensor: step 10, image 1 of 3 RedOctane X-Plorer Motherboard Replacement, Whammy Bar Sensor: step 10, image 2 of 3 RedOctane X-Plorer Motherboard Replacement, Whammy Bar Sensor: step 10, image 3 of 3
    • Remove the two 7mm Phillips #0 screws.
    • Using your fingers, remove the black wire retainer.
  11. RedOctane X-Plorer Motherboard Replacement: step 11, image 1 of 2 RedOctane X-Plorer Motherboard Replacement: step 11, image 2 of 2
    • Using one hand, remove the whammy bar and its attached components from the case.
  12. RedOctane X-Plorer Motherboard Replacement: step 12, image 1 of 1
    • Using two hands, remove the whammy bar sensor.
  13. RedOctane X-Plorer Motherboard Replacement, Motherboard: step 13, image 1 of 3 RedOctane X-Plorer Motherboard Replacement, Motherboard: step 13, image 2 of 3 RedOctane X-Plorer Motherboard Replacement, Motherboard: step 13, image 3 of 3
    • Remove the four 10mm Phillips #1 screws around the perimeter of the motherboard with a screwdriver.
    • Lift the motherboard to remove it from the case.
2 other people completed this guide.
Riley
703 Reputation
7 Guides authored
Cal Poly, Team S17-G1, Livingston Spring 2018 Member of Cal Poly, Team S17-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G1
3 Members
9 Guides authored
1 Guide Comment
Where can I but a replacement board?
Matthew - Reply
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 42
All Time: 3,075
