Asus G750JW-BBI7N05 RAM Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
81
All Time:
1,306
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Faulty or failing RAM can cause a variety of issues, from random crashing to a total loss of power. This guide will walk you through locating and replacing your laptop's RAM.
Tools
    1. Asus G750JW-BBI7N05 RAM Replacement, Battery: step 1, image 1 of 1
      • Power off and unplug your laptop, then turn it over.
      Ask FixBot
    2. Asus G750JW-BBI7N05 RAM Replacement: step 2, image 1 of 1
      • Slide the battery release latch all the way to the right. This will cause the battery to "pop" out slightly.
      Ask FixBot
    3. Asus G750JW-BBI7N05 RAM Replacement: step 3, image 1 of 1
      • Remove the battery from its compartment.
      Ask FixBot
    1. Asus G750JW-BBI7N05 RAM Replacement, RAM: step 4, image 1 of 2 Asus G750JW-BBI7N05 RAM Replacement, RAM: step 4, image 2 of 2
      • Lift up the rubber stopper on the backplate to expose one Phillips screw. Unscrew it until it becomes loose.
      • This screw is permanently connected to the backplate and cannot be removed. Unscrewing it only allows you to remove the backplate from the laptop.
      • The backpate is the plastic plate on the underside of the laptop that covers some of its easily accessible internal components.
      Ask FixBot
    2. Asus G750JW-BBI7N05 RAM Replacement: step 5, image 1 of 1
      • Use an opening tool to pry up the backplate along its edges, then remove it.
      • You may need to apply some force when prying up the backplate.
      • Keep in mind: During reassembly, replace the backplate starting from the bottom.
      Ask FixBot
    3. Asus G750JW-BBI7N05 RAM Replacement: step 6, image 1 of 2 Asus G750JW-BBI7N05 RAM Replacement: step 6, image 2 of 2
      • During the recycling process, this laptop lost some of its parts. In this step, its top two RAM modules are missing.
      • Remove each RAM module one at a time by sliding them downward out of their slots.
      Ask FixBot
1 Guide Comment
What about how to remove the other two internal RAM Modules?
Latiron London - Reply Share
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 81
All Time: 1,306
